RHS front wheel arch liner removal
Davet49
Fri Oct 28 2022, 04:07pm
Member No: #3695
I need to replace my windscreen washer pump and I believe the best way to access it is to remove the front wheel arch liner.
I can't find anything that describes how to do it.
Is it easy?
Fri Oct 28 2022, 07:49pm
Yes, one plastic rivet at the top of the arch, one on the inner wing and then about six Torx 30 screws around the edge of the bumper, two in the front of teh wheel arch and four along the bottom of the bumper.
1 User said Thank You to MGmike for this Post :
 cruiserphil (01 November 2022)
Davet49
Sun Oct 30 2022, 01:28pm
Member No: #3695
Thank you. Are the plastic rivets reuseable or will I need to buy new ones?
Sun Oct 30 2022, 05:53pm
Reusable if you're careful. The top one is a pull out centre, the inner wing one is a push centre. If one breaks it'll be the top one but you should be okay.
Davet49
Sun Oct 30 2022, 06:09pm
Member No: #3695
Thanks. I'll wait for the new pump to arrive before I tackle this and even then, it will probably have to wait until next week.
