Offside (RHD) driveshaft for 2.7Hd |
Author | Post | ||||
Davet49
![]() ![]() Member No: #3695
I need to replace the offside driveshaft as the outer CVJ has failed and apparently cannot be replaced independently of the whole driveshaft. One mechanic has been unable to find a replacement despite being given delivery dates twice. A second mechanic found a new driveshaft, but it turned out to be the wrong one when everything had been dismantled. Can anyone give me the part number of the correct part and does anyone know where to find one? | ||||
cit-rotti
![]() ![]() ![]() Member No: #3753
There are various portals to find the spare part number. However, only the PSA service portal, which is subject to a charge, is absolutely correct. Every Citroen dealer has access to this and can find the correct spare part number using your chassis number. If you write me your VIN (VF7.....), I will find the right part for you. Greetings Wolfgang |
![]() ![]() Member No: #3151
try here - Click Here - | ||||
Davet49
Wolfgang, thank you very much, the VIN number is VF7TOUHZJ78017573. MGMike - they are out of stock, but thanks for the suggestion |
cit-rotti
Your chassis number is wrong: VF7TOUHZJ78017573 Correct is: VF7TDUHZJ78017573 ORGA Nr. 11405 Original Citroen AW "new and replacement" are only available from the factory - duration???? Part numbers: Long right hand drive shaft: 3273 QZ for new original shaft approx. 505€. 3273 RA for exchange shaft approx. 260€ Short drive shaft left: 3272 QR new original shaft approx. 505€ 3272 QS for replacement shaft approx. 260€ |
TheGerman
![]() ![]() Member No: #3175
maybe this one in England - Click Here - |
Davet49
Thanks again Wolfgang - I have poassed those details on to my mechanic to sort out whilst I go on holiday (not in the C6!). I have also passed your link on to him 'TheGerman' and thank you also for your help. |
Xynactra
![]() ![]() Member No: #5035
I have a 3273SQ, maybe this one fits ![]() |
Davet49
It might do - it does appear to be the same as a 3273QZ. At the moment I have found a supply via e-bay (!) of new ones, so I am trying that first. Otherwise I will get back to you. Thank you, and I apologise for the delay in getting back to you but I have been away on holiday. Dave |
rwb
![]() ![]() Member No: #1988
I had two driveshafts from here - Click Here - £175 for two in November 2019. In fact, the listings are still on eBay - Click Here - - Click Here - |
Davet49
Phil, Yes, I found that and ordered one from them. It is now with my mechanic and I will be talking to him on Monday to ensure that it is correct. The people at Transitparts have confirmed that it is the correct part, but their website disagrees! We shall see. Thanks for the suggestion. Oddly enough it was BL Autos that suggested I use eBay. |
Davet49
I am pleased to say that the driveshaft from Transitparts is now fitted and appears to be working perfectly. Thanks to everyone for their help and advice. |
