Power steering line leak |
gbl |
Member No: #936
Hi, I have noticed a small hydraulic fluid leak at the front right corner of my car. It seems to come from the power steering line with the cooling fins where a hose is crimped on to the line. The photo is taken through the front grille, and the leak is visible in the red circle. The bumper needs to be removed for a closer inspection or replacement. Any experiences to share here? Does it suddenly develop into a much bigger leak? Any alternatives to replacing the entire line (part number 4013 76)? Thanks for your suggestions! |
I'm looking at this and wondering if it's actually 'feedback' from the return pipe under the wheel arch. | ||
trysberg |
Member No: #1701
Hello! Old thread but I wonder if you discovered where the leak came from? I have the same leak. |
Fraunie |
Member No: #3763
I have got the very same leak too, and the part is "nfp"... Looks like a joint. A solution could be to take it out and hand it over to a hydraulics-pipe expert to repair it? | ||
ozeddy |
Member No: #5052
Hi, I too am interested in how the leak was resolved, please. .. and what does "nfp" mean here, please? | ||
mtee |
Member No: #1924
ozeddy wrote ... and what does "nfp" mean here, please? NFP = non fourni plus = no longer available. |
Citrofix |
Member No: #1722
ozeddy wrote ... Hi, I too am interested in how the leak was resolved, please. .. and what does "nfp" mean here, please? Just put on a normal hose clip and tighten it, worked for me recently. I have also repaired leak from the HP tube-hose-tube for the front suspension out from the pump valve block on several c6's - cutting off the hose and put on new 250 bar hose(1000 bar burst pressure) and 2 new press-couplings (is that what it is called?) Cheers, Christian |
trysberg |
Member No: #1701
Normal hose clip worked for me too. | ||
