Wiring Diagramm Headlight left
Xynactra
Sat Jun 04 2022, 08:23am
Member No: #5035
Hi!
Has someone a wiring Diagramm from the left Headlight?
The High beam has failed and i want to check if the Signal comes to the Headlight.
Thank you!
Nico
cit-rotti
Sat Jun 04 2022, 09:41am
Member No: #3753
Circuit diagrams are available here in the forum under "Technical documentation".
Xynactra
Sat Jun 04 2022, 04:46pm
Member No: #5035
Yeah i saw that but there is none for the headlight..
Xynactra
Sun Jun 05 2022, 09:08am
Member No: #5035
I've now got my hands on a wiring diagram.
How do i know which wire is for what? they are not labled in the wiring diagram/ headlight.
The left headlight is the "2610".
Xynactra
Sun Jun 05 2022, 09:21am
Member No: #5035
Ok got it, Found it under Tools. The Signal for the Main Beam ist the Number 2801 on Pin 1.
sotweedfactor
Sun Jun 05 2022, 03:52pm
Member No: #2185
Where did you find the wiring diagram? Is it available online?
Xynactra
Mon Jun 06 2022, 07:04am
Member No: #5035
Got my hands on the original Manual, so if you need anything.. =)
The reason for the Main Beam to fail was a broken wire directly IN the connector to the Solenoid.. Works again now =)
TheGerman
Mon Jun 06 2022, 08:08pm
Member No: #3175
Xynactra wrote ...
etwa so ?
Xynactra
Mon Jun 06 2022, 08:15pm
Member No: #5035
Fast, war bei mir wirklich im Pin gebrochen. Du hast es von aussen nicht erkennt und je nach dem wie das Kabel gerade gebogen wary hat es sporadisch Kontakt gemacht..
Hab den Stecker komplett abgeschnitten, 2 Pins raufgeklemmt und mit nem Tupf Heissleim im Stecker fixiert zur Sicherhet.
