Vibrations while steering (mostly to the right) + while suspension wobbles |
sorin0310
![]() ![]() Member No: #4973
Hi guys! I just got myself a 2006 Citroen C6 with 2.7 HDI engine, and not long after I bought it, I've realized two odd things happening on an open road: 1. I get a vibration in the entire car while steering (more to the right, less to the left, but still there) at lower speeds - especially while getting in and out of roundabouts, and this vibration is also felt a bit into the steering wheel; since no crazy issues have been found while the car has been checked underneath by a mechanic, I am asking you guys - has anybody came across this issue and found out what exactly had to be fixed? 2. While I am accelerating on a bumpy road, and the suspension starts to wobble, I feel other (similar) vibration on the front end of the car (especially when the wobble makes the suspension push the nose up); is this related to the issue mentioned at point 1 - like, same thing causing vibrations in both situations? If not, do you have any idea what can cause this one? Thanks in advance, guys! Best wishes from Romania! ![]() |
adybadguy
![]() ![]() Member No: #3617
Hello, For about 2 weeks , i have something similar with what you describe at the first point. But in my case the steering wheel is vibrating only on stand still. |
