Cabin heating |
jba4576 |
Member No: #2816
Hi When I drive the car the cabin heating works, but at idle there is no heating, until I drive again. What can cause such a problem? |
Is the heater fan running. Try manually increasing the fan speed to see what happens. |
jba4576 |
Member No: #2816
Increasing fan speed at idle gives only more cold air in - no heated air until I drive. | ||
Fraunie |
Member No: #3763
Have you checked the coolant level? It might be low... |
joopajaa |
Member No: #3261
Seems like the is air in the system - possible with low fluid levl as jba stated. Mine does "goggling" sound at idle or with engine off-aux heater on as there is some air at the moment after some repairs on the cooling system. -> no proper coolant circulate in the heater core in cabin. |
