Ongoing Suspension fault. |
Rosb |
Member No: #4784
Have just replaced the rear stiffness regulator on my 2006 2.7 C6 however the car continues to get a suspension fault message and service message that comes on for about 5 secs then disappears. The faultThe rear of the car seems to fluctuate from being ok to slight hardness with some occasions dropping to very hard. Wondering what you folk suggest we check next ? |
Hello Rosb, If a suspension fault message appears there should be a fault logged in the ECU readable using DiagBox or Lexia which should help to identify the problem. Best regards, Phil C. |
Hello Rosb, Just looked at your original post. With all the work done on your suspension, were the vehicle heights reset? Best regards, Phil C. |
Rosb |
Member No: #4784
Cheers Guys. I have just managed to get Lexia working so will see what has been logged and will pass onto the guy who is helping me your comments. Thanks again | ||
