Drivers heated seat fuse |
Tux2609 |
Member No: #4887
I can't figure out which one is G36 Drivers heated seat fuse. It should be in the top row but there's a difference between the diagram and the actual fuses. | ||
It should be the fifth one from the right or the first blue one from the right.. |
Tux2609 wrote ... I can't figure out which one is G36 Drivers heated seat fuse. It should be in the top row but there's a difference between the diagram and the actual fuses. Your not wrong! I figured it was in reverse actually. I have photo of the one in the C6 to compare it to. I’ll post that when I get to a pc br] |
321dave wrote ... Tux2609 wrote ... I can't figure out which one is G36 Drivers heated seat fuse. It should be in the top row but there's a difference between the diagram and the actual fuses. Your not wrong! I figured it was in reverse actually. I have photo of the one in the C6 to compare it to. I’ll post that when I get to a pc. Pity i need to rotate the image 90 degrees anti-clockwise. You can see the two orange 5amp fuses at the other end of the diagram above from Citroen. But if you follow the colours it actually matches the diagram, but it backwards in the car! br] |
Tux2609 |
Member No: #4887
321dave wrote ... 321dave wrote ... Tux2609 wrote ... I can't figure out which one is G36 Drivers heated seat fuse. It should be in the top row but there's a difference between the diagram and the actual fuses. Your not wrong! I figured it was in reverse actually. I have photo of the one in the C6 to compare it to. I’ll post that when I get to a pc. Pity i need to rotate the image 90 degrees anti-clockwise. You can see the two orange 5amp fuses at the other end of the diagram above from Citroen. But if you follow the colours it actually matches the diagram, but it backwards in the car! br] So, the one I'm after should be the first blue 15amp from the left. Thanks! |
Tux2609 wrote ... 321dave wrote ... 321dave wrote ... Tux2609 wrote ... I can't figure out which one is G36 Drivers heated seat fuse. It should be in the top row but there's a difference between the diagram and the actual fuses. Your not wrong! I figured it was in reverse actually. I have photo of the one in the C6 to compare it to. I’ll post that when I get to a pc. Pity i need to rotate the image 90 degrees anti-clockwise. You can see the two orange 5amp fuses at the other end of the diagram above from Citroen. But if you follow the colours it actually matches the diagram, but it backwards in the car! br] So, the one I'm after should be the first blue 15amp from the left. Thanks! That’s correct! Glad to help. |
