Right hand side driveshaft removal |
CorneSoutAfrica |
Member No: #2836
Hi Everyone Long time no post, although alot has happened. I removed the DPS and the front oxidizing catalyst to clean the ash from them. It started with the rear bank oxidizing catalyst that rusted through where the clamp to the DPF is situated. Anycase, the right hand side inner driveshaft boot on my car is damaged, I want to replace it, but I am unsure on how to remove the driveshaft with the intermediate bearing sitting behind the inner driveshaft boot, should the driveshaft just be able to pull out once it is loose from the wheel hub or am I missing something? Thanks Corne |
Hi Corne, You're missing something The bearing has a clamp plate on the carrier. Two torx screws at 1 o'clock and 7 o'clock. The top one just needs loosening as the plate slides out on a groove. The bottom one needs to come all the way out to allow the plate to be removed. I think the design intention was to allow the bearing to come out without removing the plate, just swinging it away from the bearing but there's just not enough room! You'll need to rotate the shaft to line up the recessed sections of the joint to allow access to the screw heads and use 1/4" or 3/8" torx bits and lots of extensions to get to them. I hope you have the car in the air as the bearing could be really tight and the use of a very long leaver may be required. On the other hand it could fall out! All the best |
CorneSoutAfrica |
Member No: #2836
I just saw what you mean! Thank you! There is loads of space with the catalyst removed, guess now it will go relatively easy! I will report back Kind regards Corne |
CorneSoutAfrica |
Member No: #2836
I got it all out. But how do you remove the triaxle from the triaxle cup? It seems to not just slide out? Am I missing something? | ||
It's better if you can get the boot on from the outer end and not dismantle the inner CV joint. The Tri axle is held in the pot by "dimples" in the metal case but can usually be removed with a sharp rap of a mallet (usually without damage!). Once you get one clear the others will fall out as you would expect. This probably doesn't need saying but... make sure you get the correct replacement boot as it's not a "universal" type. It has three rubber "blocks" that fit in the pot recessed sections. |
D5252T |
Member No: #4478
I can't get right shaft out of gearbox. How did you get it out? I removed catalyst and bearing housing. And I hit it with sledge hammer. And it does not move a bit. Did you pry it out or hammer it out? | ||
The first time, I had the engine out and the shaft had split at the inner joint. The bearing was completely seized in the carrier, needing a significant amount of hammering to get it out. Once freed off, it made the second removal a simple task of levering from below. The shaft usually only needs a small amount of effort to leaver it (with a little shock) from the gearbox. It's important to keep it straight as any sideway movement causes it to bind. If you have the bearing carrier off it might be prudent to put it back on to support the alignment of the shaft. |
D5252T |
Member No: #4478
I got it out. I put carrier back order to keep it alligned. It needed like hundred hits with sledge hammer. Also I tried to destroy the bearing with Dremel - I am not sure if it helped. Thanks! | ||
D5252T |
Member No: #4478
How do I press the new bearing to bearing carrier? I guess that must be done before I attach it to gearbox? | ||
Make sure the carrier and bearing are spotless and it should slide in! It's not an interference fit, doesn't need any force to insert, hence the need for the outer retaining plate. |
