2.7 Gearbox Earthing Strap Location.
onthecut
Sat Sep 18 2021, 05:45pm
Member No: #2793
Fairly simple question, I hope. Exactly where on the body is the end of the gearbox earthing strap fixed ? Despite being quite new, I seem to have an increasingly lazy starter motor and I need to check it's not a furry earth.
Also, am I right in thinking the +ve from the battery runs directly to the starter post, or are there any intermediate jnctions I need to check. ?
Thanks, Mike.
Sun Sep 19 2021, 08:06am
I do not have the answer, but: Have you measured current draw or voltage during starting ? If the voltage drops a lot the connection might be OK and you have the usual 2.7-problem of gradually failing starter bearings. If there is only slight voltage drop, then reconsider the connection hypothesis.
Sun Sep 19 2021, 05:56pm
I had to wrack my brain to remember where it is
You need to remove the air filter box and there should be a cable from the top of the box across to the inner wing/chassis rail.
But as Tjensen says, unless you have history of the motor having been replaced I would start (pun intended ) there...
I think the +ve runs to the distribution box with the red cover to the right of the air filter and then down to the motor.
