Oil pressure sensor |
Nikolaj |
Member No: #4047
Where is the oil pressure sensor located on the engine? And where to get the sensor? (Autodoc only has oil level sensor) From time to time, i get "oil pressure low warning", and it happens when I release the brake, after waiting for green light, engine rpm drops a bit when gearbox engage, as soon as I touch the accelerator, warning dissapears again, but it's quite anoing. I have experienced bad oil pressure sensors in my previous XJ6, so I'll start with that. I plan on changing the oilpump at 200.000km when cambelt is due. (I'm now at 183.000km) |
Nikolaj |
Member No: #4047
OK, found a C6 switch locally. (Autodoc also have it, but you have to search for Jaguar S-type) And the location from Land Rover forum. (between valve cover and EGR pipe.) |
arconell3 |
Member No: #922
Hmmm, just a piece of advice: before putting in a new oil pressure sensor, get an oil change done. Make sure you get the proper oil quality, i.e. Total 5W30 Ineo ECS, or equivalent. Don't use a 0W.. oil viscosity, because that may cause a low oil pressure warning all by itself.... Also, oil dilution (diluted with diesel fuel) will cause the same problem if you're lucky, if not, or when ignored, it may cause a seized engine. What I am trying to say is that in these 2.7 engines a defective oil pressure sensor is extremely rare, which means that any low oil pressure warning invariably signals a real oil pressure problem! regards, Robert |
Nikolaj |
Member No: #4047
But oil pressure sensors/switch do go, I haven't had the problem since I changed it, and I do run Total 5W30 Ineo. ECS. But a small advice if you get an aftermarket sensor, the original sensor has a "cone" shaped thread,(smaller diameter at the tip) so it will be absolutly tight sitting in the cylinder head, the new sensor had normal straight thread like a bolt, so I had to grind it in "cone" shape, not ideal, but it works. Just tested it on "Autobahn", and no leaks. I don't know if Citroen still has the sensor, but I would try them first next time, just to get the thread right. Come to think of it, I think the Jaguar sensor I changed a few years back had the same "cone" thread, so must have got an original sensor then. |
