Opening the boot from inside when no power |
chrisisbd |
Member No: #2258
I need to do the "opening the boot in an emergency" bit because there's no power to the back of the car at all (boot lock, all rear lights not working). I can get access OK through the back seats but I haven't a clue where the hole you poke the screwdriver into is. The picture in the owner's manual is most unhelpful. All I can see is the plastic handgrip for lifting the boot and that's all, where is the 'hole' relative to that? |
It's a [%*^#@!] to find as it's hidden by the boot seal. Its in the lock mechanism at the bottom centre of the boot lid. I think slightly (about 25mm) left of the centre line and about 10mm down from the boot lid bottom edge. Good luck finding it.. |
chrisisbd |
Member No: #2258
Thanks, found it! Now I have th boot open I can sort out the battery connector etc. Basically some hairy bicepped monkey has overtightened the +ve connection and deformed the clamp so it doesn't grip properly. A bit of judicious metal bashing should get it back into reasonable shape I think. | ||
C6Marcy |
Member No: #4417
If that fails I have one you can have for £10 posted | ||
