Just bought myself a C6 after years of wanting one, what maintainance do I do need to get done? |
Yangster |
Member No: #4295
Just bought me a C6 after years of wanting one, wondering if anyone can advise what maintenance would be advisable to get done upon purchase? It has done 80k miles and is a 2007 model, can't tell if the cam belt has been done or not, is there a way to tell or should I just go ahead get this done as a precaution, is there anything else I should have done aside from an oil change? Many thanks for any help... |
Fraunie |
Member No: #3763
If you are not sure, what has been done, I would recommend to change all belts (3). An oil- and filter change of course. All other filters: Fuel, Air, Interior filter Check the front axle for wear, especially all rubber parts... |
Hello Yangster, Congratulations on your purchase. As per Fraunie and consider changing the coolant inlet tank and the clutched pulley on the alternator. Best regards, Phil C. |
Fraunie |
Member No: #3763
You're right Phil: Changing the pulley BEFORE it breaks the alternator is definitely a good idea and can save a lot of money... | ||
C6Marcy |
Member No: #4417
Fraunie wrote ... If you are not sure, what has been done, I would recommend to change all belts (3). An oil- and filter change of course. All other filters: Fuel, Air, Interior filter Check the front axle for wear, especially all rubber parts... Maybe a gearbox flush to save the valve block failing? |
Yangster |
Member No: #4295
Thank you for all the suggestions, very helpful! does anyone know of a good c6 specialist in the Kent area? | ||
David Hallworth |
I'm not sure of anybody in the Kent area, however, BL Auto's in Welwyn Garden City are very well known for being superb in the C6 circles and have been used by numerous members on here. I quite often travel from Glasgow down to have them work on my cars if it's not something I want to do myself. David. |
Yangster |
Member No: #4295
Thanks David, great to know! | ||
