Speedmeter and seat adjustment |
TKyngas |
Member No: #1588
Hello everybody! I have problem with my C6. 1. Speedmeters component is burned out. (See photo) Is this fault only in meter assembly or is the actual fault somevere else? (If I put new one it will immediately break) 2. To right seat does not move. (No driwers seat, left hand side streering) It moves under on a control on a tester and the commands of the cars own keys go to the ECU.(Check with tester) What could cause this? 3. The inside heat control works, but no control functions are displayed. Other functions are visible. (Radio, navigation...) ??? Best Regards, Tapio from finland |
eke |
Member No: #624
Hello Tapsa, 1. I would send the speedometer to Elkotron in Tuusula. My speedometer went black about year ago and it was fixed there 2. No idea 3. do you mean that it shows nothing on the screen when you increase or decrease heat ? Br Eke, also in Oulu |
