Door led ambient lightning |
c6chile |
Member No: #3816
Hi, on one of my 2.7 the led lights on 4 doors, the ashtray light, the dimmer backlight, suspension and gearbox modes buttons backlights aren't working properly, I checked the door led and is Lit but very dim, same with other backlights not enough power, I measured voltage at the bulb terminal of the ashtray lighting and I got 0,3 volts. I ve read all the threads on this forum and none seems to cover this issue. When pressing the dimmer buttons the only thing I get is a change in brightness on the speedometer display, GPS screen and the main set of buttons backlight around the radio. The lower line of buttons above the ashtray don't backlight with enough power either. ( I had to dissasemble them to see the led was on ) So far I've checked all the fuses, all the connections to the BSi, BSM and everything seems to be ok. I´m thinking it could be a ground problem? On my other 2.7 everything works perfectly. Thanks in advance to anyone who might know how to fix this regards PG |
cit-rotti |
Member No: #3753
Hi You need to check the ground connections |
c6chile |
Member No: #3816
I´ve checked the grounds on engine bay next to the fuse box and on the rear next to battery and everything seems to be ok, Do you know any other ground points I should check? thanks PG |
c6chile wrote ... I´ve checked the grounds on engine bay next to the fuse box and on the rear next to battery and everything seems to be ok, Do you know any other ground points I should check? thanks PG I noticed this earth under the dash in one of the technical files recently. Might be of help. |
ingmar55555 |
Member No: #4280
PG, I also have an issue with this lighting. Even the workshop could not get it to work, dimming the dash works flawless. Must admit that haven't removed the door panels yet to do some measurements, since I have been rather busy with some other things. Br. Ingmar |
