C6 sound insulation
Mon Jun 01 2020, 10:53am
There is a setting in Lexia to chose between 17" 225-55 and 18" 245-45 to tell the electronic systems (but I have not changed it each time)
 gkirkov (04 June 2020)
ChrisW
Mon Jun 01 2020, 10:56am
Member No: #1335
Thank you, Radox and gkirkov, for your replies. You have to be careful that you do not increase the tyre radius too much otherwise it will foul the wheel arch and the speedo reads too low. There are plenty of "tyre size calculator" sites on the web that calculate the radius from any combination of xxx/yyRzz tyre size. Before making any change, do check the clearance between the tyre and wheel arch
I changed things in two steps. First, several years ago, I put 245/50R18 tyres on my Atlantique wheels. Definite improvement and they did not cause a problem with speedo or fouling, but the clearance between the tyre and wheel arch was tight. I did not think to use 225/55R18's but, as they are slightly larger radius, I think they may be too big. 225/60R18's will definitely be too big.
My suggestion is to go to 245/50R18 on your Atlantiques at your next tyre change as it worked on mine and gives a benefit (but check first). I have been driving on non-standard tyres for at least 6 years now and have never had a problem with the suspension.
1 User said Thank You to ChrisW for this Post :
Mon Jun 01 2020, 05:29pm
ChrisW wrote ...
Just to show the difference between 245 45 18 and 245 50 18:
Basically you just need to be careful and drive a couple of mph below the actual limits although it is within the 10% 'leeway' one is 'supposedly' allowed.
 cruiserphil (03 June 2020) , gkirkov (04 June 2020)
gkirkov
Thu Jun 04 2020, 11:22pm
Member No: #3981
ChrisW wrote ...
Could you please give me more details on the difference you felt going to 245 50 R18? How noticeable it was? Was it just felt with minor but sharp road imperfections or it was felt at handling too? Also, what brand and age were the 245 45 ones and the new 245 50 ones? I just bought a 245 45 r18 Primacy 4s but can exchange them if I'm confident it will be worth the "risk"
P.S. My main concern is that your improvement was mainly due to newer and better tyres, I'm a little skeptical I personally could feel just 11% increase in sidewall, but who knows...
Thanks
C6Dave, I'm using the exact same calculator, it's very convenient
ChrisW
Fri Jun 12 2020, 05:34pm
Member No: #1335
gkirkov - I am sorry for the delay in replying. The old tyres were the original Michelins and had done 18000 miles and needed replacing. The new ones were Nexen 7000. I chose Nexen (budget) tyres rather than the big names, like Michelin, because a tyre fitter told me that the cheaper tyres have thinner, more flexible side walls, which should be more comfortable. I want comfort and don't care about "performance".
I saw a significant improvement going from 245/45R18 to 245/50R18 and a bigger improvement going from 245/50R18 to 225/60R17. Essentially, the more rubber between rim and road the quieter and more comfortable. I saw no difference in handling but I am a "gentle" driver.
3 User said Thank You to ChrisW for this Post :
 C6Dave (12 June 2020) , cruiserphil (15 June 2020) , gkirkov (15 June 2020)
gkirkov
Mon Jun 15 2020, 10:46pm
Member No: #3981
You're welcome, but wife killed it all - she doesn't seem to be able to tell whether the ride height is set to normal or middle position... So the eventual 1/10th increase in comfort is out of the equation I'll be waiting to run into a fellow C6 driver with 50s and compare for myself
bargi
Wed Aug 05 2020, 08:56pm
Member No: #2590
1 User said Thank You to bargi for this Post :
 cruiserphil (06 August 2020)
Kaloteck
Thu Aug 06 2020, 01:16pm
Member No: #1271
Hey ppl, come on, why are you messing up with original manufacturer's tyre size?
That's just not kosher...
mtee
Thu Aug 06 2020, 05:02pm
Member No: #1924
ChrisW wrote ...
My tyre fitter told the same, so I bought such soft sidewall tyres. They are indeed more comfortable when using the normal tyre pressure, but the other side of the coin - or wheel in this context - is that they are also more fragile.
I destroyed one such front tyre by driving over a stone on a small dirt road, not high speed.
The fitter told that the tyre pressure recommended by Citroën is too low for such a soft tyre and heavy car.
1 User said Thank You to mtee for this Post :
 cruiserphil (07 August 2020)
Go to page   <<
