Engine speed (crankshaft) sensor on 2.2 HDi |
rwb |
Member No: #1988
Part 1920.EH. Anyone know where it is? The ServiceBox diagram is rather unhelpful. Do I stand a chance?! (The 407 which hasn't moved for three weeks now won't start and has come up with P0339. I parameter measurements engine speed shows as zero even when cranking.) Ta... |
Had a look for you as well and there is no 'guide' for changing it, only a general parts image No (7) Now looking online for more info I found this which explains what it does and given that you need to be looking down at the end around the timing belt area. Sorry can't offer more help but hopefully you can locate it. |
I'm racking my grey matter to think where it is on my C5's! I think it's pretty much behind the front pulley to the rear of the engine. Look for a cable running down the rear o/s corner of the engine and that should be it! Think you'll need to remove the front pulley to get at the retaining bolt.... |
rwb |
Member No: #1988
Ta. Sounds like it's well beyond me then. I hope Mobile Mechanic is still working... |
