Air con hose to bottom of condenser |
Author | Post | ||||
sidenham
![]() ![]() ![]() Member No: #3993
Has anyone had to replace this pipe from the bulkhead to the bottom of the condenser. There are a few advertised on flee bay with part no's; 9659576280 & 9684486580 all have a difference in the flexy pipe end , but some are saying will fit a C6. Does anyone know if these pipes might fit without any serious problem ie; lengths etc. My pipe into the condenser snapped at the O ring end. Absolute Pain. ![]() ![]() |
Sent you a parts list for the air con and heater hoses but am a bit confused by the 'fuel line pipe from the oil cooler to Thurm valve' description? Searching on 647750 I found a complete used set from a Pug 407 in the Netherlands but there should be some from cars being broken in the UK? |
![]() ![]() Member No: #3151
C6Dave wrote ... Sent you a parts list for the air con and heater hoses but am a bit confused by the 'fuel line pipe from the oil cooler to Thurm valve' description? Dave, It's in the 2.7 fuel line tech doc item 16 I would say. Sidenham, I'll check on my scrap engine for you tomorrow. |
sidenham
Thanks Mike , Tried to add a pic of it but failed to include it.![]() Done it, Yippee |
Dave, It's in the 2.7 fuel line tech doc item 16 I would say. Ah 1920HN ![]() I've looked on line and 'maybe' one is available from Citroen but at close to £100. All the 'used' listings I found are 'out of stock'. Going back to the aircon pipe 647750 looking at on 'Service Box' it's fitted to the 2.2 and 2.7 C6 and the 2.2 and 2.7 Pug 407. ![]() I can't say whether one from another model would be long enough but.... I had a quick measure of an aircon pipe I could reach on my car and the metal part looks to be close to 15mm OD so you could go 'old school'. Buy the cheapest pipe set you can find with the correct end, cut it and your original on a metal section and use a 15mm compression coupler (they are readily available from any plumbing supplies store) to join the 2? |
sidenham
Thanks Lads those are the pipes concerned. The fuel pipe, I'm looking to find a quick release straight 90 or 45 degree elbow with the same internal diameter. Would the old fitting just need the pipe warming to remove it and again to refit a new one. As for the air con pipe that's great info, might look to buy one from Poland for £30+ and have an Air Conditioning Fabricator local in New Romney to re-clamp the end properly. Or do as Dave said, check the O/D of the pipe and get a coupling that fits both. What sort off pressure is flowing through the pipe under load ?? |
sidenham wrote ... What sort off pressure is flowing through the pipe under load ?? Very good question and one which I hadn't thought of but I found this in the Air Con checks guide in the Tech Docs section and it can get quite high. ![]() |
sidenham
Dave, those are serious numbers, think I'll be looking to have a new end section professionally replaced. Might not pass an MOT examiners bright eyes with a brass plumbing fitting staring back at him. The only other thing that I might be able to do is get my pipe bending kit out and find a new route to get the extra length needed from another models pipe. | ||||
sidenham wrote ... Dave, those are serious numbers, think I'll be looking to have a new end section professionally replaced. Remember the DS LHM system ran at circa 2.5X that pressure (54 Bar) so it's nothing exceptional for a Citroen ![]() BTW you can get 15mm compression fittings in Chrome and is the Air Con system even part of an MOT? |
sorry, the one I have fell apart when I tried to remove it! |
sidenham
Yep know that feeling, Thanks anyway Mike, really appreciate you trying to get one for me. I'll try to make the pipe work from the tee piece and get a new 8mm I/d quick release, straight or bent from somewhere. Thanks. | ||||
sidenham
Dave, The pipe I need is just under 10mm so might try with one of those straight chrome compression fittings on my old pipe first before I butcher a new tear drop end. | ||||
sidenham wrote ... Dave, The pipe I need is just under 10mm so might try with one of those straight chrome compression fittings on my old pipe first before I butcher a new tear drop end. Sounds like a plan, let us know how you get on as it could help someone else in the future. |
sidenham
Got the chance of a air con pipe off of a C5 estate in Spain. Ticks all the boxes as regards look, only difference is it has an electrical switch below the filling valve. Doe's anyone know if the lower condenser connection is the same as on the C6. Only difference in the part numbers, the C6 is 6477-50, the C5 6477-5P. The main number C6 #9684486580 , C5 #9684493980. What do you think Lads, should I buy it. ![]() |
sidenham
Pictures of Pipe ![]() |
