Rear center console panel dead
czarlz
Thu Jan 23 2020, 08:14am
Member No: #3806
Hi,
After fixing (not myself) the flaps in ventilation (right half was blowing cold, left - hot) I noticed that the rear center console panel is dead. I checked all the fuses, but they are OK. Everything else works well. Have you ever come across such an issue?
Thu Jan 23 2020, 12:08pm
Never had an issue but it's possible that a button on the rear has been pressed so check that out 1st.
From the handbook:
Activation - rear panel
When you press button Auto, the automatic mode automatically and simultaneously controls the air flow and air distribution for the rear air conditioning.
The warning lamp on button A lights up.
It is recommended to keep both air vents open.
Deactivation
A press on any of the buttons B, C or D, deactivates the automatic operation of the rear air conditioning. the warning lamp on button A goes out.
Note : If the air conditioning in the front of the cabin is stopped (function deactivated in the « Air conditioning » menu or via the control 4 for adjusting the air flow), then the rear automatic air conditioning is not available.
ADJUSTING THE AIR FLOW
If you press buttons B or D you increase or decrease the flow for the rear air conditioning.
The number of diode(s) lit up, composing the symbol for air flow (helix, situated between buttons B and D) expresses its power level.
To deactivate the air flow and air distribution for the rear air conditioning, press successively on button D so that all the diodes go out
DISTRIBUTION TO FOOTWELLS/HEADS
Successive presses on button C will modify the distribution of the air flow.
Three directions are available :
Passengers' heads.
Passenger footwells.
Passengers' heads and footwells.
The arrow lit up indicates the distribution of air chosen manually. In « AUTO » mode, no arrow lights up.
ADJUSTMENT OF THE FLOW OF AIR INTO THE STORAGE UNDER THE FRONT CENTRAL ARMREST
If you choose a maximum flow of air in the rear by pressing B and distribution towards passenger's heads by pressing C, having closed the rear air vents, you will obtain a maximum flow of air into the storage beneath the armrest.
If playing with the rear controls with the ignition on and aircon set to on in the main menus, the fuses are fine (including the ones in the boot?) then a connector may have been disturbed when changing the flaps?
czarlz
Thu Jan 23 2020, 01:26pm
Member No: #3806
In my case the rear panel does not react at all. I can press any button I want, will change nothing. No LED is on too, except for the cigarette lighter. How can I get to the connectors? Do I have to completely disassemble the whole center console?
Thu Jan 23 2020, 03:21pm
Before you do anything else, what temperature is it where you are?
At around anything below +6c the aircon auto cuts out to protect the system so if it's auto off then the rear panel will also be switched off.
czarlz
Fri Jan 24 2020, 09:04am
Member No: #3806
It is about +6C here now, but the whole thing was not working at +20C too. It looks like either they forgot to connect it, or it has died.
Paulius
Fri Jan 24 2020, 06:02pm
Member No: #1821
Well, you could try computer diagnostics. There is a separate ECU for the rear control panel and it lets you test the buttons and LEDs. You could maybe see if there is communication with the ECU. But I wouldn't know what to do with that information if I was you anyway..
czarlz
Mon Jan 27 2020, 07:23am
Member No: #3806
All is clear and sorted now. They must have forgotten to connect the plug. As simple as that. I fixed it in approx. 1 minute. Thanks for your answers.
