Airco failure |
pauldubber |
Member No: #3136
When the outside temp is below 6 degree celsius, the airco of my c6 stops working and no moisture is removed from inside the car. Anybody familiar with this fact? | ||
No errors showing via Lexia? Have a read of - Click Here - as there are a couple of things that can 'switch off' the air con compressor. |
pauldubber |
Member No: #3136
No error showing via the lexia, airco comes back when above 6 degrees celsius | ||
Hello pauldubber, My understanding from my experience of to railway vehicle air con is that the air conditioning compressor is inhibited at low temperatures to prevent freezing of the refrigerant in the condenser. So this is what may be happening in your case. Best regards, Phil C. |
keithc |
Member No: #2584
- Click Here - You are the first person I've heard having the same issue as me. Mine stops at 4 degrees. All I can find out is like Phil says, that the aircon stops below a certain temp to save the compressor. All I can think is it could be a fault flap not letting fresh air in or something. I was going to try changing the flaps sometime to see if it helps. You are more than welcome to try first if you |
rwb |
Member No: #1988
You might be able to get more information in parameter measurements. For example, if there is less than about 1.5 bar of gas pressure then it won't run (and will show "low pressure safety check: active"). IIRC there are other conditions under which the computer will not allow the AC to run. |
keithc |
Member No: #2584
I had my aircon serviced (tested/drained/refilled etc) by a well recommended crowd and put in a new genuine Citroen cabin sensor to no avail. I also meant to say if I put my finger on the temp sensor in the wing mirror and the temperature on the central display goes over 5 degrees the air con starts to work again. | ||
Keith C, You and pauldubber appear to have found the threshold temperature for operation. I would believe all is fine. The trains I referred to have air conditioning by Stone Iberica. I distinctly remember them explaining the reason for the lower ambient temperature cut off. On these trains it's 15degC. I remember them also explaining how they also limit cooling in ambient tempertaures from 40degC upwards to minimise the thermal shock experienced when moving suddenly from a cool interior to those kind of ambient temperatures which could cause people to collapse! Best regards, Phil C. |
keithc |
Member No: #2584
My issue is why the car fogs up instantly when the air con shuts down. That's the problem I have which can make driving dangerous. There must be an issue if others have no issue with their cabin fogging up. | ||
Hello Keith, I'd be definitely looking for some kind of moisture source. Best regards, Phil C. |
keithc |
Member No: #2584
I have done and the car is bone dry. No damp carpets or boot or anything. It's so frustrating! So much so I've contemplated taking out the interior and carpets just to be sure. But I've not been brave enough to yet! | ||
Jas16 |
Member No: #2994
try picking a temperature on the Auto setting and leaving it there. I assume that when the air re-circulation stays internal and the air con is off, windows mist up, so you may have to force fresh, external air to be drawn in. | ||
keithc |
Member No: #2584
Ya I press the button to force fresh air in. Doesn't do a whole pile. I've to put the fan speed to max and keep it there just to keep the front window and both sides partially clear. Lucky I've a sunroof which I keep tilted which helps a good bit. That's why I think I may have a flap issue stopping the fresh air getting in properly. |
David Hallworth |
I remember when collecting my 3.0 we heard the air conditioning compressor engaging and disengaging. When it came back from having the gearbox rebuilt I wasn't hearing it at all, then tonight when the temperature had risen a bit I noticed it working again. It never twigged but it appears mine isn't clicking in and out below about 6 degrees too. Mine also mists up which is irritating. I'm sure on my old 2007 2.7 that the compressor used to work at all temperatures, this 2012 seems to do funny things! David. |
