Suspension setting switch |
C6Howie |
Member No: #4110
Hi Suspension setting switch has dropped down into trim around gear stick, how can one remove the trim to gain access to the switch ? |
The trim just 'clips' in. With a trim tool simply lever gently at the front end, then the sides and it should come out. I had mine out but took it very carefully in case any moulded in clips broke. It would be better done with the trim and cabin 'warm' rather than cold. |
