C6owners :: Forums :: Owners Reviews and Road Tests :: C6 owners and drivers reviews |
National Car Test (NCT) - Republic of Ireland |
Hello C6Dave, They measure imbalance across the axle using MAHA MSD3000 equipment. If you Google it you'll find YouTube videos of the equipment. Best regards, Phil C. |
Hello 321Dave, Could your imbalance in the rear be due to a problem in the AMVAR variable damping head in one of the struts? Check the plug connections. You should carry out the soft/firm test in Diagbox to see if you can get a feel for it. This might show up a hard sphere (you could swap them around to see if the problem follows them). I wouldn't be convinced yet that your rear struts are shot. The 09 car went through NCT recently. The rear struts are original - imbalance 8%. The front struts are 2 years old and new - imbalance 21%. Let us know how you get on, Best regards, Phil C. |
cruiserphil wrote ... Hello 321Dave, Could your imbalance in the rear be due to a problem in the AMVAR variable damping head in one of the struts? Check the plug connections. You should carry out the soft/firm test in Diagbox to see if you can get a feel for it. This might show up a hard sphere (you could swap them around to see if the problem follows them). I wouldn't be convinced yet that your rear struts are shot. The 09 car went through NCT recently. The rear struts are original - imbalance 8%. The front struts are 2 years old and new - imbalance 21%. Let us know how you get on, Best regards, Phil C. Many thanks for the suggestions to try Phil. That's great, I will take a closer look this week and report back any findings. All the best 321dave |
