How Low Does Your C6 Go?
xantiaboy
Wed Sep 11 2019, 02:21pm
Member No: #3978
Hi all, if I do not use my C6 for a couple of days the suspension height drops.
Being a new C6 owner I wanted to know if this is a normal 'characteristic'?
Photo included.
When it is this low the rear tyres are just touching the inner wheel arch.
Wed Sep 11 2019, 02:34pm
No, the C6 should be "no-sink" when parked. A small internal leak somewhere ? But if it's not a problem and gets up for driving fast, maybe nothing to use money on.
Wed Sep 11 2019, 04:58pm
As Tjensen says it should stay at ride height when switched off. The front may drop very slightly and lift when unlocked but it's a very small movement.
Paulius
Thu Sep 12 2019, 06:57pm
Member No: #1821
Hmm, there are rear rubber end stops. They are visible when the wheels are taken off - are they still there?
Sat Sep 14 2019, 11:21am
Hello Xantiaboy,
The rear firmness regulator may be slowly leaking back to the reservoir tank. If you search the forum you'll find posts on this. Not an immediate problem once you remember to let it rise before you move off.
2 User said Thank You to cruiserphil for this Post :
 C6Dave (6 Days ago) , xantiaboy (4 Days ago)
