changing preset temperature airco
bijs
Sun Sep 08 2019, 11:03am
Member No: #3890
hello,
I'm driving my c6 now for 6 months without any problems.
But there is one thing that bothers me : always as i step in the car the airco starts at a temperature of 21 C , and i find that too cold.
Is it possible to set the temp to fix it as you turn off the engine or set the starting up temp to a different temp ?
I've got a diagbox tool but i couldn't find a way too change it .
gr Bert ( netherlands )
Sun Sep 08 2019, 04:17pm
Never seen that on any of my 6's, temperature always stays at whatever I have it set to.
Mon Sep 09 2019, 08:19am
Temperature should be saved along with seat position & side mirrors positions in the memory, assuming you have memory function.
To store settings press M, then press & hold 1 or 2 until you hear a confirmation noise.
bijs
Mon Sep 09 2019, 01:31pm
Member No: #3890
Thanks for the reaction on my question.
I tried to set the memory 1 and 2 on different positions and temp but always as i turn off the key and back on the temp is 21 C.
Is there a "factory" reset for the car ?
Or is this a thing when set up for deliver a new car (as possible in the diagbox ) ?
Mon Sep 09 2019, 03:45pm
Setting to 21c from the dashboard and running the car is a 'reset' position the driver can carry out but there is something strange going on with your car.
When you have the engine running can you still set the temperatures up or down and individually side to side?
bijs
Mon Sep 09 2019, 06:46pm
Member No: #3890
The airco is working perfect, i can set all temperatures i want and also two together and apart from each other.
But after turning the key it starts up with 21 C and every side on its own.
eke
Tue Sep 10 2019, 04:01pm
Member No: #624
If the car has webasto heater, the temperature when starting is always 21 C. I was told so by official Citroen service here in Finland. If your car does not have webasto, then it is strange behaviour.
2 User said Thank You to eke for this Post :
 C6Dave (10 September 2019) , cruiserphil (10 September 2019)
Fraunie
Tue Sep 10 2019, 05:03pm
Member No: #3763
I have a Webasto heater and the same phenomenon: It is always set at "Auto" and 21° C. I tried to set it in the Diagbox (marked no heater) but it doesn't change...
eke
Tue Sep 10 2019, 05:08pm
Member No: #624
You can't change that (Auto and 21 °C), if the car has webasto
1 User said Thank You to eke for this Post :
 C6Dave (11 September 2019)
bijs
Tue Sep 10 2019, 05:23pm
Member No: #3890
That's it !
I don't have a Webasto but an Eberspacher hydronic d5ws unit in my car.
So in the summer deactivating the heater doesn't work.
thank you all for your input.
gr Bert
joopajaa
Fri Oct 04 2019, 05:59am
Member No: #3261
This behaviour is because there is a relay behind heater panel - it cuts the CAN-bus from the panel when car is not running allowing heater to run fan in pre-heating. It can be over-run by a simple switch "summer/winter" - in summer position the relay is bypassed with this switch and the CAN is not cut when car is shut down.
The default 21 degrees cannot be changed but with "summer" position the car will remember the previous setting when starting.
Dagence
Thu Oct 17 2019, 08:38am
Member No: #3006
I got my Webasto installed my by a local Webasto expert a year ago or so. He asked me what temp set I want the car to start with.He proposed 21 but I wanted 22 and so it does, 22 every time.No idea how he made it but I can ask.
1 User said Thank You to Dagence for this Post :
 Fraunie (17 October 2019)
Fraunie
Thu Oct 17 2019, 05:11pm
Member No: #3763
Yes, please ask him...
Dagence
Fri Oct 18 2019, 05:48am
Member No: #3006
I called him and of course he didn´t remember. After long thinking he said that most likely it has to do with aircon/temp unit memory. Has to do with ignition on/off / diconnecting the unit will memorise latest value used ??? All in all he was really uncertain about a year ago done work. Sorry I couldn´t hope more.
And he has no Lexia or similar...
 cruiserphil (18 October 2019)
