Part #5280.V8 - PTFE anti-extrusion ring for LDS pipes
mister_iainm
Thu Sep 05 2019, 05:15pm
Member No: #3253
Currently hunting for [one of] the above. The little 'O' ring (#5280.V7) that it backs-up is still available, but Citroen say the back-up ring is not.
Does anybody have one of these in a packet that they can spare, or have some dimensions (I'm guessing this is an industry-standard part from somewhere or other)?!
Fri Sep 06 2019, 11:59am
Hi Mister from Melrose, pretty sure Citroen never followed industrial standards for their hydraulic connections, it was always bespoke.
Do you mind me asking if your original anti extrusion ring is lost or damaged?
Fri Sep 06 2019, 12:12pm
Hi Mister from Melrose again.
5280.V8 anti extrusion ring (45 degree scarf cut)
thickness in the axial direction is 1.3mm
outer diameter is 11mm
radial thickness is 1.3mm
No accuracy given on above as I've lost my good Vernier caliper, my faithful Mitutoyo!
Fri Sep 06 2019, 12:18pm
Barnwells may be able to manufacture or supply if you get stuck
mister_iainm
Sun Sep 08 2019, 12:19pm
Member No: #3253
Howdy,
The original ring is [very slightly] abraded around one outer edge, although (once the new 'O' ring arrives) it may well still serve its purpose.
However... it does appear to be an ISO standard metric component (I mic'd it as well), and I have since obtained 10 from an company called "Claron Hydraulic Seals Ltd", who were very helpful indeed (once they realised I didn't want to buy 10000...!)
I will provide an update in due course.
Caio,
Iain
