2.7 HDI Excessive Fuel Pressure |
mister_iainm |
Member No: #3253
Anybody experienced this? Symptoms: overtaking with full throttle, car cuts out momentarily at or near full boost (quite an abrupt loss of power), then returns to normal over the next minute or so. Brings up a de-pollution fault which persists for about 24 hours (or perhaps until the car has properly "gone to sleep"?). Diagnostics say excessive fuel rail pressure single occurrence (code 1166 - I will check again?) - car is otherwise fine. I couldn't find anything on this forum, although Google turned up similar (though rare/isolated) incidents with C5. Iain M |
travlician |
Member No: #350
Yep, caused by dirt in the diesel pump inlet (the one under the hood). Ended up replacing it. | ||
Just to confirm Travilcans post, here is the related error document (available in Tech Docs but you need to download and unzip) |
AndreSMCXXMC6 |
Member No: #615
Have you changed out the DIESEL filter in time (more often then prescribed). | ||
