Fehler P0243 C6 DT17 SID201
cit-rotti
Thu May 23 2019, 08:13pm
Member No: #3753
Hello,
P0243 Turbo pressure regulation electrovalve 1 (rear) control fault: Mechanical problem.
The error occurs after a short driving time - the C6 then has little power and turns a maximum of 3000 rpm at idle.
There is no warning light - only loss of power.
When the car is turned off and restarted, the turbo power will work again for a few miles - then everything repeats itself.
Does anyone know this error / problem?
Which possibilities of repair are there?
Citroen only supplies a complete turbo with wastegate. And prohibits the wastegate from the turbocharger to separate, disassemble and release its attachment.
Greeting Wolfgang
joopajaa
Fri May 24 2019, 11:55am
Member No: #3261
I would buy a second hand unit from C5/C6/407/607/Jaguar S-type/Landrover if the price for new one is too much.
And I mean the whole turbo.
Sat May 25 2019, 06:24pm
check this thread - Click Here - . It's a known problem on early turbos (I've got one waiting to be fixed!).
