Permanent fault. Diesel issues.. help! |
jenskuhn |
Member No: #2756
Got suddenly stuck in economy mode goong off the highway after driving 100kph for a few hours without any problems. After running a Lexia diag I got fault codes: P0002 Fuel flow regulation. Current too high. P0092 Fuel pressure regulation electrovalve. Short circuit to + P1351 Pre-post heating relay circuit. Relay controlled. Plugs not controlled. Before going on the trip I had noticed that the coolant level was low. I was able to fill 2,5 litre before going close to the «full»-mark. I dont know if the diesel pressure issues is related to this? Any ideas where to start? Can I get it out of limp mode at least? |
Ignore the P1351 for now that's likely to be one or more glow plugs faulty or the glow plug relay. But these won't cause the economy mode. The other two sound like a fuel supply issue and I would start by changing the fuel filter as the easy first option. After that you'll need to investigate the fuel pump and the supply from there to the injectors. |
jenskuhn |
Member No: #2756
P0092 Fuel pressure regulation electrovalve. Short circuit to + Where can I locate this one? Can someone show me a photo please |
