Driver seat (LHD) |
Dagence |
Member No: #3006
Fixed my driver seat heat element.For some reason I can´t install my seat back anymore because the seat does not travel far back enough to reveal front bolts. I have the seat on carage floor and all seems otherwise normal, it goes all way to max front position but not far enough to rear position ( missing 4 cm ). 3.0 Hdi. Have not touched to any motors or any moving parts else except seat leather. As seat reaches to it´s max.(4cm short) rear position I can hear Ecu clicking and cutting of like it does on the other end. Bolts are not in away. Seat is now upside down and I can test it, motor is fine, seat mvoes smoothly.Can´t see anything blocking the movement. Any idea what could be wrong? Seat is with memory and position sensor readings are ok. I believe this is some mechnacical issue. |
