Lag acelerator
rmonf24
Sat Mar 23 2019, 08:47am
Member No: #3300
Well that my citroen c6 since always and noticed that when you step on the accelerator does not respond immediately, someone knows if Lexia can be solved?
Thank you.
Sat Mar 23 2019, 10:08am
Hello, most likely an issue with your Swirl pipes and or actuator. Link to PDF repair info below by Vaho.
Sat Mar 23 2019, 01:27pm
Is the Swirl system the same on 3.0 Hdi ? When I have a "lag" I suspect the gearbox learning system and think it becomes better after a little fresh driving. But I may be wrong and should check this system ? The lazyness is only sometimes and mostly in town traffic. Accelleration on tho open road is good.
ul9601
Sun Mar 24 2019, 08:36am
Member No: #1975
I've driven three 2.7 HDi, they are more or less the same, unfortunately.
I've done swirl valve jobs and made no difference.
Sun Mar 24 2019, 09:38am
Tjensen wrote ...
No, Tjensen; no swirl valve system on the 3. Well, no visible system, at least...
Mon Mar 25 2019, 06:29am
Don't forget it's a 2.7 and prone to turbo lag from a standing start.
Mon Mar 25 2019, 09:50am
e3steve,
I think I spotted swirl valves. Lower mounted and piped differently. Have a look lower down the front of the engine for the front one. Let me know what you think.
