Broken window!
Dowen
Sat Mar 16 2019, 12:48pm
Member No: #3847
I've had the car 2 days! Somehow I managed to slam the door with the window up too much? Is that possible? It seemed to be up beyond the door frame!Can anyone give me advice fitting new window? Is there any height adjustments?
You can only guess how pleased I was ! !
It's right side front.
Sat Mar 16 2019, 12:58pm
Yes it can happen (frozen and stuck in upper position ? Or lack of electricity/battery ?). Laminated glass (2 or 3 layers). Check right part no with your VIN number and hope for the best when it comes to availability and price ! Never happened to me, but one of my first anxiety-topics with the C6. Classic "frameless door" problem.
AndreSMCXXMC6
Sat Mar 16 2019, 03:09pm
Member No: #615
Re-initialize and checking the battery when having put in another window.
Be careful when putting a new window in as they can easily brake even in the hand of a garage man.
bargi
Fri Apr 12 2019, 12:24pm
Member No: #2590
You will want to check the door lock that activates the window dropping down. If this is gone then you're only going to smash your window again
