Loud "blob" sound after installing xcarlink |
Author | Post | ||||
madst
![]() ![]() Member No: #3419
Jakub, seems I can't order from that Polish webshop. I found this, which seems to be identical with what you ended up with after the soldering? Would you agree that it is similar? - Click Here - |
madst
Status: I bought the connector from the Polish webshop, - Click Here -, and soldered it as described above by Jakub - and it works! No thumps or blobs any more ![]() So now I am finally using the xcarlink. It works, but it is quite quirky. As an example, in order to make or receive handsfree calls while listening to radio or the built in jukebox, you need at first to switch to the CD changer input and then you are able to speak and listen. I assume there could be other hands free solutions out there which are a lot better! Thanks again, Jakub, for your inout. It made all the difference. |
