battery jump Starter Booster |
Asaab |
Member No: #2691
Hi my car is driving once a week and the battery gating low. it is possible to use battery jump Starter Booster from the front connections? or i need to connect direct to the battery.? Thanks |
Front connections works fine. That's what they are there for.. | ||
Jas16 |
Member No: #2994
yep agree, you can use the front connections under the bonnet | ||
Asaab |
Member No: #2691
thanks i try with two difrent electronic boosters, no power to start the car. with car to car battery, the engine is start up. any solution to keep the battery alive for car that stay inside garage? Thanks |
A maintenance charger ! But check your battery ! You should get a start even after 2-4 months, so something might be wrong. Simplest answer : bad battery and/or to little charging before storage. Test the battery, charge fully up. | ||
