hydraulic leak
Asaab
Fri Aug 17 2018, 04:04pm
Member No: #2691
hi,
i expiriance oil leak from the rubber pipe part under the aft part of the car.
is somebody know if it is high or low oil prussure?
can i just replace it with rubber pipe with two bands?
Thanks
Asaf
travlician
Sat Aug 18 2018, 02:22am
Member No: #350
It's an hydraulic return hose, however return circuit on the C6 is also pressurized at 2-3 bar. Hydraulic fluid is very much oil like so rubber should be made for that.
Asaab
Sat Aug 18 2018, 03:54am
Member No: #2691
Thanks
the rubber pipe is located between plastic pips.
it is posible to replace only the rubber part?
any part number for it?
thanks
Sat Aug 18 2018, 05:35am
From Citroën you have to buy the whole pipe from front to back of car.
You can replace the rubber hose section yourself, with jubilee clips to secure.
Asaab
Sat Aug 18 2018, 05:43am
Member No: #2691
Thanks for fast answer.
is simple jubilee clips will hold 2-3 Bar like what Travlician say before?
Thanks
Sat Aug 18 2018, 10:15am
Asaab wrote ...
Thanks
Hi Asaab,
Some people have fitted a small section of rubber fuel hose. It has a similiar internal diameter. I bought the replacement pipe and removed the bit I needed. No need to depressurise before fitting, as others stated it's a low pressure return pipe. It will leak a very small amount when you unclip it, so best have a rag or cloth underneath. The pipe I bought had one clip and I had to reuse the old clamp type clip for the other end. Very fast to replace when you have everything you need ready. Link to forum pictures here.
Sun Aug 19 2018, 11:06pm
Asaab wrote ...
Thanks
Jubilee clips are fine. The Citroën specialist, B.L.Autos, who look my cars, have repaired this pipe on 50-100 C6, with no failures. Virtually every C6 will need this sometime in its life.
Asaab
Mon Aug 20 2018, 03:44am
Member No: #2691
Thank you very much for the thorough answers.
I'll do what you said
