Wiring issue (start problem) |
jba4576 |
Member No: #2816
Hi Does anyone happens to know the route and connections for wire B132B (see attached picture). The picture shows it is directly connected from BSM (fuse power supply) to ECU (injector), but when I look in the car and measure there is no direct connection. The wire starts correctly named B132B (beige) at BSM but comes to ECU (pin K4) with no mark on and is green like K3 (other 12v supply). Perhaps its spliced on the way. I have 2 C6 and both are constructed as described. I have all the wiring diagrams, but it only shows what the picture show. The harness or connection description do not have any explanation. Odd! Any lead or help is appriciated? |
