Scratches in the driver and passenger door windows
Norman
Mon Jul 16 2018, 10:27am
Member No: #364
Hi all cleaning the car yesterday I noticed there are two vertical Scratches in both windows. There doesn't appear to be any noise when the windows lift and lower but something is causing the scratches and I wondered if anyone has had the same possible problem.
2010 C6 2.2 Auto exclusive in Black
Jas16
Thu Jul 19 2018, 07:26am
Member No: #2994
Hello, I have the same issue, but on hot sunny days I can hear the screeching noise of rubber on dry glass. I am sure there are bits of dust and grime that cause this, maybe the C6 rubber seals are too good in this case.
Mine are quite heavily scratched particularly the fronts. Also I think my glass is beginning to delaminate but I will keep going as long as possible as is, replacing the glass seems the only option.
On the side, I did buy a detailer brush to remove as much [%*^#@!] as I can between the glass and seals when i wash the car.
3 User said Thank You to Jas16 for this Post :
 cruiserphil (19 July 2018) , 321dave (19 July 2018) , Norman (19 July 2018)
julianaray
Mon Oct 15 2018, 08:14am
Member No: #3678
I faced the exact same issue. That was horrible experience.
1 User said Thank You to julianaray for this Post :
 Norman (18 October 2018)
