Knocking.
keithc
Fri Jun 22 2018, 10:31am
Member No: #2584
Hi all, recently I've changed the complete hub, tie rod end and drop link on the front right (driver's side) and drop link on the passenger side (need to replace the tie rod end on passenger side too) but I get a faint knocking at low speeds/coming down off speed bumps or over a bad road I've to travel on when dropping my son off to the child minder every morning. I am 99% sure it's coming from the driver's side so what else should I check? It's not a bad knock but it annoys me! Thanks!
Fri Jun 22 2018, 05:07pm
Sub frame bushes/bolts are tight?
Sat Jun 23 2018, 10:00am
keithc wrote ...
Hi Keith,
I had something simliar and changed everything like yourself and after a short amount of time a faint knock returned. Long story short, it turned out to be the anti roll bar drop link on the passenger side. I was told by a work colleague the knock you hear is most times on the opposite side (the sound travels) and he was correct and he then mentioned the quality of the part I purchased. Sometimes it doesn't pay to buy cheaper parts ( I had). It worked for me anyway. Funny the play on my antiroll drop link (6 months on the car) was very little, but the car and bad road unfortunately amplified the sound a lot. Worth cheacking again. How many miles on your C6 now? I replaced my anti-roll bar rubber bushes as well, but not for noise for handling reasons, but they can knock as well.
Hope that helps.
Dave
keithc
Wed Jun 27 2018, 11:29am
Member No: #2584
Dave-Retired wrote ...
Might try them and see.
Car has 235,000 kms now Dave. I have replaced the drop link on the passenger side too. Have to do the tie rod end yet but don't think that's it. I know I have a loose heat shield and I see a bolt or two missing from the undertray so will put on the tie rod end, try fix the heat shield and replace the missing bolts as well as look at the sub frame items and take it from there.
keithc
Sun Jul 15 2018, 09:50pm
Member No: #2584
I replaced the front passenger tie rod yesterday and it was pretty gone. More so than I imagined. Plus it was siezed on, had to hacksaw the bolt on the hub off plus use a vicegrips with the inner bolt jammed with a spanner to turn it off the inner rod.
I also had two bolts missing from the undertray and the heat shield is not as loose as I thought it was.
So after all that the "knocking" is gone. Happy Days!!
