2.7 HDI hesitation (not sure if its correct word)
Fri Jul 06 2018, 09:25pm
joopajaa
Question: what is this? Its leaking fuel. Part no? Its under/behind the intake Y, above the thermo housing.
[br wrote
EDIT: Its part no. 1574E8. It seems I need to change the whole piping :/
Hi joopajaa,
well done is noticing the leak, that brittle pipe/connection gets very brittle over time and leaks fuel intially very slowly, but then gets worse! Your best bet is replacing the injector pipes as well. I have mine bought, but no leak as yet, but I'm checking just in case. E3steve mentioned it on the forum if I remember well this issue along with the vacuum pipes for the manifold that run across the top of the engine as well.
Dave
joopajaa
Mon Aug 06 2018, 08:52am
Member No: #3261
Comment on this after the belt change: My front intake was quite loose. I had to tighten 2 lugs near the belt side. Not sure yet if this has any affect but I think there was some leaking going on because of this. So check your intakes!
Also it seems my fix with sikaflex-type adhesive + split silicon hose over the piping near Y-part has stopped the leak.
1 User said Thank You to joopajaa for this Post :
 321dave (07 Aug : 15:32)
Go to page   <<
