Eight year old battery replaced with...........
speedfix
Thu May 03 2018, 08:34am
Wow time flies, best car ever owned! nothing to report apart from a new battery replacement [eight years old] service items and oil filter changes at 12000 miles IMO a must with the crank bearing set up and pistons oil cooled and heated.
Battery type calcium 100ah with 850 cca 4 year warranty Ebay £77.00.
Smart charging system so battery registration configuration was reset BSI.
Jobs to do sometime, water pump cam belt + tensioners high pressure fuel pump belt aux belt thermostat housing etc.
I may do the heater plugs even though working correctly they can with time be difficult to remove, tip always remove with a hot engine.
