Cranking but not starting after wash
Thu Mar 22 2018, 09:50am
Dennis,
You posted in the 3.0HDi section but you didn't say what engine your car has. If it's the 3.0Hdi the fuel filter, for example, is positioned in rear of the fuel tank under the car.
2 User said Thank You to cruiserphil for this Post :
 dennis_vogelius (22 March 2018) , C6Dave (22 March 2018)
Thu Mar 22 2018, 10:13am
cruiserphil wrote ...
Dennis,
Hi Phil,
apologies to Dennis. I had not realised the fuel filter was at the back with the tank pump on the 3.0hdi?
I'm getting schooled this morning this is such a good forum.
dennis_vogelius
Thu Mar 22 2018, 10:48am
Member No: #3477
Hmmmm, I might be I HOPE a little closer to my problem here.
There is sitting some wiring to the common rail I guess, and one is broken, and it was disconected
I hope this is the problem, cause for now I am about to EXPLODE.
dennis_vogelius
Thu Mar 22 2018, 11:01am
Member No: #3477
Okay, this is what I have found.
The connector with the broken wire is sitting RIGHT under the common rail connector.
I don't know what it is doing or IF it has anything to do with my starting problem
Thu Mar 22 2018, 12:01pm
Hi Dennis,
Did you remove the white connector with the broken wire or was it disconnected? The wire broken is most likely your issue. I would try and reconnect it. Do you have experience reconnecting wires?
You could solder a new piece of cable between the break and heat strink a cover to protect it. Then try starting the engine. Looks very likely car wont start as it's receiveing no signal from the sensor to the Ecu computer. Well done finding the broken wire. Your nearly solved!
Thu Mar 22 2018, 12:02pm
Looks like a few cm of wiring is missing.... Can't say what it's for but it would be a good starting point to repair that.
Will see if I can find a wiring diagram for it but don't hold your breath.....
BTW to save any more confusion added the car details to your signature
EDIT: looks like your going to have to pay for an hours access to service.citroen.com to get the required wiring diagram if you want to try and trace it.
Thu Mar 22 2018, 10:11pm
Hello Dennis,
It would help as Dave Retired says to say what engine we're dealing with (2.2, 2.7, 3.0 diesel)?
dennis_vogelius
Fri Mar 23 2018, 08:44am
Member No: #3477
Hello Dennis,
It is allready writen that it is a 3.0 HDI 240 HP from 2010
1 User said Thank You to dennis_vogelius for this Post :
 cruiserphil (23 March 2018)
dennis_vogelius
Fri Mar 23 2018, 08:47am
Member No: #3477
Okidoki. It did not help anything to connect the wire that was broken.
Now I am thinking if this could be a problem with the ECM. Crank but no start is a typicall sign of a ECM problem also
Guess in french they call it the reve / relais
Fri Mar 23 2018, 09:49pm
dennis_vogelius wrote ...
Hi Dennis,
what a pity. Thought it was the wire. Best get the lexia setup and plugged in. That will be able to help pin point something wrong. let us know how your getting on. Wonder what it could be? You did charge and check the output voltage of the battery? How is your key fob battery? I had a key once with a bad battery but then the doors wouldn't lock or unlock.
dennis_vogelius
Fri Mar 23 2018, 10:10pm
Member No: #3477
321dave wrote ...
Hi Dennis,
Battery got a good charge, and I have 3 keys, and result is the same with them all.
I am as of now also fighting getting Lexia installed. somehow things really are messing with me.
To be honest I was also convinced that my problem would have been solved fixing that key, but NOPE.
A very sad and frustrated C6 owner right now
Sat Mar 24 2018, 02:25pm
321dave wrote ...
Hi Dennis,
Hi Dennis,
Are you installing on an old Xp machine or something new like windows 10.
dennis_vogelius
Sat Mar 24 2018, 04:55pm
Member No: #3477
321dave wrote ...
321dave wrote ...
Hi Dennis,
Hi Dennis,
I have tried to install on a Win 10, XP and virtual machine XP. Getting same problem when i need to install the Actia drivers. Instead of finding MULTI-INSTANCE drivers it give me UMDF.
Things are REALLY not going well here (:
Sat Mar 24 2018, 05:57pm
Hi Dennis,
Ok, where did you get your Lexia and software. I believe there is good and bad versions that are sold. I'll try and find the reference to a link about it on the forum. When your installing are you connected to the internet. Also, I wonder is the any forum member not to far from you to help you with a Lexia? Anyone you know of?
Sat Mar 24 2018, 06:39pm
321dave wrote ...
I got mine from Vehicle Diagnostics UK on eBay - Click Here - it installed 1st time with zero issues on my Notebook/pad running Win 10
 cruiserphil (26 March 2018)
Go to page   <<        >>
