b1102, Fault in the link between the headlamps,
grnb
Thu Feb 08 2018, 06:39am
Member No: #3200
I have this fault in projectours calculator and my right light turned left and stayed this way. If i try to do lamp tests it begins normally and than beeing interrupted. left lamp moves then, right is dead but lights very well. There are no any warnings on the screen or flashing lights on dashboard. Anyone had this kind of fault?
Thu Feb 08 2018, 09:11am
B1102 doesn't appear in the list of Citroen error codes so a Google of it brings up 'Battery Voltage Low' for Hyundai and Kia:
B1102 Description Supplemental Restraints System Control Module (SRSCM) checks input voltage when IG ON to make air bag system work properly. If input voltage is out of normal range, there can be malfunction in system operation. In this case, Check battery and charging system. The SRSCM sets DTC B1102 and turns warning light on if voltage below threshold value is detected for more than 4 sec. (If voltage within threshold value is detected When the SRSCM returns to normal condition. SRSCM regards DTC as being cleared and turns warning light off).
Read more: - Click Here -
It seems like a good place to start, checking the battery and wiring connectors to the lights?
grnb
Thu Feb 08 2018, 04:50pm
Member No: #3200
this code is written in diagbox, projektours calculator and it means literaly : Fault in the link between the headlamps
grnb
Wed Feb 21 2018, 03:06pm
Member No: #3200
mayby anyone know how the fron lights are connected to each other? is it done by bsm or bsi? where are any conections related to this?
Wed Feb 21 2018, 06:35pm
Take a look through the wiring diagrams - Click Here -
