foglight
datmbn
Tue Sep 21 2010, 07:38am
Member No: #193
To day i was at the cars first MOT and the only complain was tha the foglights pointing to high.
Is ther a easy way to adjust them ?
regards Mats
Tue Sep 21 2010, 07:47am
I don't think they are adjustable, they simply clip in place as far as I know but I'll have a quick check of the documentation.
Ignore the first part as it's the fitting/removal instructions but it needed the image to explain the last part in Blue.
EDIT: well I was wrong, you can adjust them, click to enlarge:
datmbn
Tue Sep 21 2010, 11:07am
Member No: #193
thanks
datmbn
Thu Oct 14 2010, 09:57am
Member No: #193
It was easy to adjust just pull out the position lights and reach in thro the hole and adjust.
1% falling take an withe masonit sheet or something else and mark the top of the light near the car messure 5-6 cm down and mark agen go 5 meters from the car and adjust the top of the light to the lower marking.
regards Mats
magicands
Thu Jan 29 2015, 12:47pm
Could somebody please explain how to adjust fog lights in English please as I am about to replace both of mine as the glass elements have gone opaque!!
Tue Feb 17 2015, 05:03pm
magicands wrote ...
Long(ish) Allen key -- 6mm, I seem to recall, same as the headlamps --, accessed through the under-panel and slightly off the vertical centre line of each fog light.
Some have 10mm hex-headed nylon screw heads which facilitate the reflectors' adjustment.
