Door struts
JamesHammond
Mon Jan 15 2018, 05:38pm
Member No: #3159
Hi all,
My first post so please be gentle with me.
I have a blue Exclusive which is a 2009 2.7. I am just about to start my 3rd year of ownership. The whole time I've owned the car the door struts that are supposed to keep the doors in an open position (unless a gust of wind catches it), on all four doors are absolutely useless. If the car is on the slightest of inclines the door will slam shut or open fully.
Is there a fix for this and has this been a problem for anyone else?
If there are any replacement parts required would you be good enough to share your wisdom & knowledge.
BTW, they all look quite rusty coloured.
Dave-Retired
Mon Jan 15 2018, 06:48pm
The door stops can show signs of rust on the surface (mine do probably from lack of use) and can often be 'noisy' because of that rust.
They were never 'tight' on the 3 C6 I have owned and the doors aren't lightweight, but I have had cars with far heavier doors (2 door Merc Convertible) which stayed open.
Maybe get 1 new one to compare with the old to see if they can be tightened up.
Front Door Stops part 9181J4 are £39.84 each UK retail
Rear Door Stops part 9184J3 are £33.60 each UK retail
2 User said Thank You to Dave-Retired for this Post :
 cruiserphil (3 Days ago) , JamesHammond (3 Days ago)
JamesHammond
Mon Jan 15 2018, 08:56pm
Member No: #3159
Thanks for the quick reply.
vaho
Tue Jan 16 2018, 06:22am
Member No: #2228
Each stop has two springs and generally only one of the springs fails/breaks. So the most cost effective way is to buy one front and one rear and repair the others with the good parts from the replaced stops.
2 User said Thank You to vaho for this Post :
 Dave-Retired (2 Days ago) , cruiserphil (2 Days ago)
Dave-Retired
Tue Jan 16 2018, 08:19am
vaho wrote ...
I haven't actually removed one to take a look so that's good to know vaho.
AndreSMCXXMC6
Tue Jan 16 2018, 01:39pm
Member No: #615
Order some clips 7473.FL too.
When dismounting the door panel some will brake off.
1 User said Thank You to AndreSMCXXMC6 for this Post :
Wed Jan 17 2018, 04:26am
AndreSMCXXMC6 wrote ...
They’re £1 (GBP) each! I managed to get all of mine out by using the correct tool, once the door card was separated from the door...
