change xenon light |
rmonf24 |
Member No: #3300
hello colleagues, someone changed the xenon bulb? it can be changed without dismantling the headlights ?. Thank you | ||
sotweedfactor |
Member No: #2185
You'll need to remove the headlamp from the car. Once this is done, its pretty easy: remove the rear, round black cover on the back of the headlamp unit. This reveals the xenon starter unit. Release its electrical connector; turn it anticlockwise to release and remove it. This reveals a black ring which holds the xenon bulb in place. This also undoes anti-clockwise, but look closely, there's a little black locking tab which needs to be lifted before you can turn it. Once removed, you can withdraw the xenon bulb. |
rmonf24 |
Member No: #3300
thank you very much . in the end I could do without removing the headlights, a couple of scratches in the hands but I could do. | ||
ul9601 |
Member No: #1975
rmonf24 wrote ... thank you very much . in the end I could do without removing the headlights, a couple of scratches in the hands but I could do. care to elaborate on how? cheers |
keithc |
Member No: #2584
If he had small hands like me that's prob how! I too have changed all bulbs in both headlights without removing anything. A few scratches on my hand when done and about 20 mins to do both sides. | ||
rmonf24 |
Member No: #3300
ul9601 wrote ... rmonf24 wrote ... thank you very much . in the end I could do without removing the headlights, a couple of scratches in the hands but I could do. care to elaborate on how? cheers No entiendo lo que quieres decir. Admin Edit - Translation of No entiendo lo que quieres decir. (I do not understand what you want to say) |
eke |
Member No: #624
Information how to change the bulb without removing headlights can be found here: - Click Here - | ||
Paulius |
Member No: #1821
Has anyone replaced the front amber sidelight bulbs without removing the entire assembly? | ||
keithc |
Member No: #2584
That's basically what I did eke. But I seriously doubt anyone with big hands will do it as space is tight. As for the Amber side light bulbs I've changed these without removing anything but the drivers side is very awkward with the tanks in the way. |
keithc wrote ... That's basically what I did eke. But I seriously doubt anyone with big hands will do it as space is tight. As for the Amber side light bulbs I've changed these without removing anything but the drivers side is very awkward with the tanks in the way. But the Amber side light beside the LDS tank can be accessed fairly easily with long angled needle nose pliers to gain access and the required turning force. That's how I do it anyway. |
keithc |
Member No: #2584
Do you know what? I never thought of that!! I used my hand!! | ||
