Speedometer Woes |
vaho |
Member No: #2228
Sure but maybe the 8 legged one can be replaced with 3 legged one because there is actually only three contact points, or so it seems. So then when the legs of this one will fit then it can be installed: As said I am no expert in this field. |
Paulius |
Member No: #1821
Ok, so I've ordered both chips. I'll try to do some research while I wait for the parts and will consult with an electronics guy if it indeed is possible to just use the 3-legged part. Will let you all know as soon as I figure this out! | ||
Paulius wrote ... Or bond a piece of heatsink onto them...?Yes, but it would be nice to have the more powerful version so that it would not get as hot. |
e3steve wrote ... Or bond a piece of heatsink onto them...? Is there room for a 12v fan from a computer power supply or CPU....? |
Paulius |
Member No: #1821
Dave-Retired wrote ... e3steve wrote ... Or bond a piece of heatsink onto them...? Is there room for a 12v fan from a computer power supply or CPU....? There are smaller fans than those from computers. I would go for some micro heatsinks as mentioned above. I tend to think that there are only a few components worth cooling anyways. |
Paulius |
Member No: #1821
Okay, an update. My instrument cluster was still mostly working, it would tend to not power up in colder weather. But I didn't want to risk it burning out so I finally managed to do the "fix". I decided to go with the original 8-legged MOFSET chip and just added a radiator to it so that it wouldn't get as hot. Hopefully it will last for another 250K kilometers I've attached a picture showing the solderjob a local electronics shop did and the "radiator". Unit powered right up from the first "blink" and is working brilliantly now. |
Paulius |
Member No: #1821
Damn it.. This morning it failed to power up again... When dismantling the unit i couldn't help but notice a small shard of glass inside. Could it be that it somehow got craked ant the gas pressure from the display itself escaped, making it "difficult" to power up when cold? |
vaho |
Member No: #2228
Hi all. Yesterday was the day when my cluster gave me a puff of smoke followed by total darkness. After opening it up it was clear that the mosfet transistor was burned. During the checking the specialist also found out that one of the two usual transistors was also bad. It was time to search the parts. Could not find them according to my earlier suggestion in this thread so went to the local electronics store and the guy gave me substitutions. Had my doubts but after all was soldered and connected to the car the instrument cluster worked again. Success!! The soldering job is done very well. The parts that I ended up using: Mosfet - IRF9321PBF, P-FET, 30V, 15A, 1,5W SO8 Transistors - TSM05N03CW, N-FET, 30V, 5.0A, 3W, 0.06R, SOT223 These parts are supposedly much more powerful than the originals so who knows. I have not too much knowledge about this stuff but I am happy that my speedometer works again. Overall cost was 2,50 euros for parts (one mosfet and two other transistors) and 40 euros for soldering job, total 42,50 euros |
