Speedometer Woes
Tue Oct 10 2017, 09:16am
The speedo on my C6 has decided to spit it's dummy, I sent it down to STSTech in Somerset and Simon has discovered that the actual VDU (Visual Display Unit) has failed.
So I'm after another one.............. It doesn't matter if it's working or not, nor does it matter about the mileage as it's going to be broken for the parts.......
If anybody has one or knows of one I'd greatly appreciate any pointers......
robingc33
Tue Oct 10 2017, 07:28pm
Member No: #2303
I still have my original dead display having eventually bitten the bullet and got a new one. It had chip(s) replaced around the regulator circuit more than once. I've no idea if the display itself still works tho it did (briefly) after each repair attempt.
We can discuss further by PM if it's of interest?
Robin
Tue Oct 10 2017, 07:48pm
PM sent
Sun Oct 15 2017, 08:41am
I now have another speedo in my hand, which will be sent to STSTech on Monday. so hopefully he can repair mine.
Paulius
Wed Oct 25 2017, 01:49pm
Member No: #1821
Has anyone got an idea on what the actual failing partis? My display failed to turn on the other day, and though it is fine now, I would very much like to replace that transistor/coil/whatever before it fails competely and causes more damage.
Wed Oct 25 2017, 10:36pm
Despite managing to get my hands on another speedo, it was to say the least "beyond repair" so I'm back to begging for another faulty one.........
vaho
Thu Oct 26 2017, 06:35am
Member No: #2228
Hi Paulius
The parts that are failing are mostly the transistors and SI4431 P-Channel Mosfet:
The transistors can be replaced with BSP 51 ones and the Mosfet with IRL 3803S. Information from the germans and since I have very little knowledge in this field I have no idea from where to get the parts.
2 User said Thank You to vaho for this Post :
 Paulius (27 October 2017) , cruiserphil (30 October 2017)
vaho
Thu Oct 26 2017, 08:30am
Member No: #2228
A bit more information - the eight legged transistor is:
SI4431BDY-E3 Transistor P-Kanal-MOSFET 30V 7,5A 2,5W SO8
Apparently gets very hot and may prematurely fail hence the replacement with more powerful one as described in my previous post.
The other two transistors are:
BSP51 Transistor npn 60V 1,0A 1,5W SOT223
Use the soldering tin L-Sn63PbAg.
Do not know what any of these numbers or letters mean..:-)
A better picture after the replacement of two transistors:
4 User said Thank You to vaho for this Post :
 e3steve (26 October 2017) , C6Dave (26 October 2017) , cruiserphil (26 October 2017) , Paulius (27 October 2017)
Thu Oct 26 2017, 11:09am
vaho wrote ...
Googling the number gets some results - Click Here -
No idea what they mean either though
Thu Oct 26 2017, 03:58pm
Time to post some pictures:
The top two pictures show what the back of the speedometer should look like.....
The bottom two pictures show the "repair" that had been carried out by somebody, prior to Robin acquiring his car.
Thu Oct 26 2017, 04:52pm
" The bottom two pictures show the "repair" that had been carried out by somebody, prior to Robin acquiring his car. "
Nasty! but what's a boy to do if the tracks are burnt out?
It's not uncommon to replace damaged tracks with wire but whats the vero board strip there for?
1 User said Thank You to MGmike for this Post :
Thu Oct 26 2017, 05:00pm
MGmike wrote ...
No idea...........
I'm not that technically minded
Paulius
Fri Oct 27 2017, 07:41am
Member No: #1821
vaho wrote ...
Hi Paulius
I tried googling that 8 legged transistor and it shows parts which are 3 (and a half?) legged (one big contact on one side, and three on the other, one beig "cut short"). Is that ok?
Other than that, I'm looking to just order these parts and resoldering them myself as a preventive measure. Should be a lot cheaper than sending it in for a professional repair.
1 User said Thank You to Paulius for this Post :
vaho
Fri Oct 27 2017, 09:11am
Member No: #2228
This one is available:
1 User said Thank You to vaho for this Post :
Paulius
Fri Oct 27 2017, 10:07am
Member No: #1821
vaho wrote ...
Yes, but it would be nice to have the more powerful version so that it would not get as hot.
