The piloted alternator in the 3.0 and its problems
Mon Jun 24 2019, 04:23pm
The sensor just came up as Lexia error report and was changed, not expensive
The steering flexible pipe is a quite common error, develops leak due to wear and vibration. Expensive part and difficult to repair, it is on the pressure side of the system. Your solution using a hydraulic service should be a solution. I never had vibrations, but maybe they did not follow all Citroen procedures when changing the pipe ? (air in the system, too low level of LDS or......)
 cruiserphil (24 June 2019)
Go to page   <<
