Electric handbrake not releasing, SOLVED
jannelehtimaki
Wed Aug 09 2017, 05:45pm
Member No: #1374
I have struggled some time with handbrake not releasing properly on one side.
Finally the solution was very simple and cheap. There is a handbrake cable suspender (see picture) on each side, but on the problematic side it was broken.
This suspender does not seem to be important but it really is. With a broken suspender the cable make an angle at the wheel end, and the return spring cannot overcome the friction caused by the angle.
I just replaced the suspender with something else (hose clamp/cable tie......) when the cable is in right position =no angle at the rear end, -everything works fine.
I hope this help someone, Br Janne
YankeeC6
Tue Feb 11 2020, 10:40am
Member No: #4242
Thank you for that post... can you please describe where this defective part is located?
Tue Feb 11 2020, 12:47pm
@YankeeC6 Looking at the parts guide (7) there going to be near the rear wheels..
