C6 Cruise Control Has Stopped Wortking |
Rooster |
Member No: #1799
Phew!!! | ||
magicands |
Rooster wrote ... Phew!!! Its a known issue with the C6, I got really Pi**ed off with mine a few months ago and slammed the steering rack adjustment back and forth a few times, this SEEMS to have ended my long running problem with loss of button function. |
Rooster |
Member No: #1799
I havent seen that method in the owners manual Magichands........ Whatever works though eh? Its a Citroen afterall. |
There's also Pappanase's trick of giving the underside of the steering column a sharp rap with your hand. That works for me! Regards, Phil C. |
ChrisW |
Member No: #1335
A huge thank you to Shaun! My cruise control had been dead for over a year. I did the steering wheel aerobics whilst driving slowly along a quiet straight road and it immediately came back to life - amazing. | ||
ChrisW wrote ... It won't last... I just bash the steering wheel rim nowadays. ColinC's, which is presently under my care, is the same!A huge thank you to Shaun! My cruise control had been dead for over a year. I did the steering wheel aerobics whilst driving slowly along a quiet straight road and it immediately came back to life - amazing. |
Hattershaun |
Another forum member has removed the cowling under the steering wheel, removed the cable ties that are holding the wiring loom, slackened the cabling, installed new loose fitting ties and all has been OK since. | ||
Hattershaun wrote ... Tried that too, Shaun, to no avail! The connector is, I seem to recall, just three or four ways; when it warms up a bit, weather-wise, and I get CYX back to a driveable status, I shall attempt to disassemble the connector and re-tension the female receptacles. This worked with my (b l o o d y awful RT3!!) rear connectors, which haven't given an issue since.Another forum member has removed the cowling under the steering wheel, removed the cable ties that are holding the wiring loom, slackened the cabling, installed new loose fitting ties and all has been OK since. The problem with CANbus systems it that the digital switching signals require 100% conductivity integrity -- 99% just doesn't cut the mustard -- therefore the tiniest alteration/addition to the circuits' resistances results in critical changes to the control laws. This becomes particularly evident when the steering column connector is disturbed and, thus, its control signals become corrupted by the slightest alteration in resistance; suddenly, a button press to, say, increase or decrease the CC's speed setpoint causes the CC to 'pause' or the change to 'limit' instead of 'cruise control'. I've witnessed this on both my and Colin's cars! It's disconcerting if one isn't ready for it or is aware that it sometimes happens... A sharp bash on the steering wheel rim and all is well again. Till the next time! |
tyanko |
Member No: #1745
Hello guys, Here is a very simple procedure I did, to bring back to life my buttons on steering wheel. 1. There are two T25 torx bolts under the steering wheel, that have to be removed. After you need to pull the shell out, with a slight twist in orger to get over the ignition key element. Inside are placed 5 connectors of COM 2000. I have pulled out every one end treated them with contact spray. @ NOTE they they has a little lock pin that you need to press down to be able to release the coupling out. This exercise takes me no more than 10 min. Now everything on my wheel works great again. |
Hi Tyanko, thanks very much for posting the pictures of the under steering cowling and switches/wires. I was wondering do you have any photos of the cable that connects to the steering column adjuster switch visible in picture 3. Is that cable made up of a two or three cables in a wrapped bundle and how many pins connect into the sockets? And have you had any issues with the column adjuster jamming, or the switch failing outright? Thanks. | ||
Wantathreelitre |
Member No: #3179
The steering wheel thing worked for me too! | ||
tyanko |
Member No: #1745
321dave wrote ... Hi Tyanko, thanks very much for posting the pictures of the under steering cowling and switches/wires. I was wondering do you have any photos of the cable that connects to the steering column adjuster switch visible in picture 3. Is that cable made up of a two or three cables in a wrapped bundle and how many pins connect into the sockets? And have you had any issues with the column adjuster jamming, or the switch failing outright? Thanks. Hey Dave, unfortunately I haven't got other pictures taken. But you can go boldly to unscrew these two T25 bolts under wheel to check these cable wiring. On second question... No, I had no issues which this switch at all. My only problem was typically with buttons for cruise/speed limiter control. Best, Tyanko |
C6Marcy |
Member No: #4417
Thank you "Tyanko" this electrical contact cleaner worked an absolute treat A very quick, easy and rewarding job |
Fraunie |
Member No: #3763
After the procedure mine worked for the first time without moving the steering column first! Thanks again for the tutorial! Btw, there is a theory saying if you treat all the connectors everywhere in the car with contact spray, the C6 will drive again as new |
M2dis |
Member No: #3475
Thanks for this tip, tyanko! I searched trough the forums years ago, possibly before your post and decided that I can live with moving the steering column. Cleaned the contacts and CC has been working nicely since then. Cant believe that it was so easy fix all along |
