Right hand-side tail lights do not turn off |
Klabbe |
Member No: #3202
Hi everyone, This is my first post at this forum, I have run in to a peculiar problem and now I hope that there is someone here who can help or advice me. Some time ago, I noticed that the right hand side tail lights on my C6 (2007, Exclusive Hdi 2.7) kept on shining after I had been out driving and all other lights had swithced off automatically. There were no warnings or any other indication that anything should be out of the ordinary, the lights just did not, (and still don't) turn off. Since I had washed the car that same day, I wondered that perhaps some water could have caused a short cirquit, but after several days in dry weather nothing has changed. The lights just don't turn off. Does anybody have any ideas about what could be causing this and how it could be resolved? Any advice? Please? |
speedfix |
Does your car have a tow bar with electrics if so could be damp in the socket. It could as you state water in one of the rear light units. Have you access to lexia? |
Klabbe |
Member No: #3202
Thanks for the reply Speedfix, -But no, I don't have any tow bar installed, that would have been the first thing I'd have checked, -got some experience of tricks that this can play with the electrics from my old CX. Unfortunately I don't have access to lexia either, -haven't had any problems with the C6 that required diagnositc tools so far, but in this case it would probably be helpful. Would you reccommend I should buy a tool with software, or do you have any other tips what I could try while I'm waiting for it to be delivered? |
speedfix |
Check the boot spare wheel well for any signs of water leakage or condensation in the light clusters. | ||
There's a warning label attached to the wiring to each rear light cluster, found near their 4-way connectors in either side of the boot. It states that "no load exceeding 10mA should be connected to the wiring, otherwise fatal fault could occur" (words similar); I wonder if a previous owner has attempted such action...(?) | ||
Klabbe wrote ... ... Does anybody have any ideas about what could be causing this and how it could be resolved? Any advice? Please? A simple workaround (perhaps temporary) fix would be to cut the negative (ground) wire to that light cluster and insert a switch. The wire is the green/yellow. You could just let the switch dangle from one of the access flaps above the netted storage shelf in the boot, which would mean opening the boot and throwing the switch each time you need to drive or leave the car; or, preferably, route a pair of wires to said location and have the 'temporary' switch next to the driver's seat... |
Klabbe |
Member No: #3202
Thanks for all the advice given so far! So far, my temparary solution has been to simply open the light cluster and remove the light bulbs when I don't expect to use the car for some time. -It's easy enough as long as you don't drop the nuts that hold the cluster in place... There is some condensation inside the cluster, but not much, and the light bulbs as well as the sockets and wiring looks dry and in as-new condition. Still, there is much more condensation on the right hand side where the light don't turn off than on the left, were everything is normal. The car has been parked in dry conditions, and have not seen water for a couple of weeks now, but still the light don't turn off. I doubt that the previuos ownvers have done much tinkering with the car by themselves. I can't see any signs of such activities, and the car came with full maintenance books. Haven't checked the boot spare wheel well yet, will do that as soon as I get around to it, but is it possible that the condensation on the light cluster is a symptom of a depostit of moisture somewhere else that is causing the problem? Thaks again! |
Klabbe wrote ... You should check the condition of the 4-way connector, found behind the boot liner.Thanks for all the advice given so far! So far, my temparary solution has been to simply open the light cluster and remove the light bulbs when I don't expect to use the car for some time. -It's easy enough as long as you don't drop the nuts that hold the cluster in place... There is some condensation inside the cluster, but not much, and the light bulbs as well as the sockets and wiring looks dry and in as-new condition. Still, there is much more condensation on the right hand side where the light don't turn off than on the left, were everything is normal. The car has been parked in dry conditions, and have not seen water for a couple of weeks now, but still the light don't turn off. I doubt that the previuos ownvers have done much tinkering with the car by themselves. I can't see any signs of such activities, and the car came with full maintenance books. Haven't checked the boot spare wheel well yet, will do that as soon as I get around to it, but is it possible that the condensation on the light cluster is a symptom of a depostit of moisture somewhere else that is causing the problem? Thaks again!
From here you can retrieve any mislaid rearlight thumb-nuts! Check for moisture in the connector. This could cause excess current-draw and, thus, cause a CANbus problem. Also, have you attempted a BSI-reset? Follow this brief: BSI reboot Put the driver's window down, open the boot and ensure all equipment is switched off. Ensure all doors are closed and remove key from the ignition. Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds. Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.). Close the boot. Switch on the side lights through the driver's window. Switch on the ignition and check system's functionality. Hold lock button on key down for 10 seconds. Remove key, open & close door test central locking system. Start the engine and complete the system's check. Failure to follow this procedure could result in incorrect BSI operation. |
